Volume limit
tiggerums
Hi all, anyone know how to override the volume limit when using headphones. Have tried a couple of widgets off the market and they dont work.
Cheers.
read though the tips n tricks section = http://androidforums.com/samsung-galaxy-s2/335847-tips-n-tricks-thread.html
As posted by HILT_M =
""""""I found the incall volume to be a little low. When you max out the volume using the volume button it actually only goes to a default setting of 87 out of 100. If you would like to change the default settings here is what you need to do.
call this number *#*#197328640#*#*
This will open the service mode menu.
choose option [5] AUDIO
choose option [1] (VOICE CALL)
choose option [1] HANDSET
choose option [1] Volume
choose option [1] SRC Speech RX Volume
choose option [5] 5_lvl : 87
press the menu button (left side)
choose Key Input
enter a value between 0 and 100, I choose 100 the loudest setting.
press ok
now press the menu button and select back this should save (don't use the right side back key you normally use to navigate the phone or you will quit out of the settings) keep hitting the menu and back until you leave the service mode menu.
You will also note you can change volume settings for other things like bluetooth, head sets, video call etc.
Note: this is not permanent, if you turn off the phone it resets back to the default levels . """""""
choose Key Input
press ok
Damn - I'd like to see if the audio output can be increased (mainly for my car stereo).
However when I try this tip, option 5 says AUDIO BLOCKED :(
Is that common ?
