Volume Locker for S2
athegn
Android Expert
I have "Volume Locker":-
https://play.google.com/store/apps/details?id=com.hourdb.volumelocker&hl=en
installed but it does not work, the way I would like, in ICS. The developer says that it may be a Samsung problem??
Any way is there a volume locker for the S2 and ICS that does keep the volume at my preset limit. If I press the volume button there should be no change or the volume should return immediately to my preset volume. I will change the preset levels in the application.
Any advice please?
