volume on my certified like new tbolt
sassy1217
O.k., I had to get a replacement phone and on this phone, the in call volume is messed up. When you turn it all the way down, it is very loud. It's so loud I have to hold it away from my ear when talking. Is anyone else having these issues?
Mine's pretty loud too, even with the volume bar all the way down. I usually talk with it an inch or so from my ear. I remember seeing elsewhere in the forum people complaining that it was too quiet. It comes in handy in loud environments. It's better than the opposite issue.
Do you use Blue Tooth? If so, try turning the volume all the way up and then back down. I believe this is a BT issue. Every time I connect to BT and make a call (car or headset) I get a volume runaway. If I don't place a call while connected to BT everything is OK. If I do place a BT call then disconnect, the phone ear speaker volume will be way too loud on the next call using only the phone. The only solution I've found so far is to adjust the volume on the ear speaker to full high then bring it back down to where you want it. I had this exact issue with my DInc and it is VERY annoying! I am stock.
I have the exact same issue been calling people back, thanks for the fix will try it out next time. Thought I was going crazy when it first happened :-)
Since this has happens on another device would seem to be a Android issue not specific to one companies screwing with the software.
I wonder if the roms our there have this corrected?
Thanks,
Bryan
