Volume rocker
M
Member98345
Guest
I noticed that when turning down the volume of the ringer with the volume rocker it doesnt automatically turn down the notification volume as well. Is there a way to set the volume rocker to adjust both notification and ringer volume to the same level? You can test this by going under Settings/Sound and Display/Ringer Volume...and try adjusting the volume with the rocker and it only adjust the Ringer Volume.
Thanks
Download "Quick Settings." Open the app and go to volume control. Up top you should see an option about setting the notification volume the same as the ringer volume. Check it and your good to go.
