Help volume
atchala
is there a way to set the volume switch for the ringer. i don't enjoy the fact that the ringer volume can be turned up or down while in my pocket or whiloe handling the phone. i'd like my ring to be the same volume every time.
someone suggested volume control. i just thing a phone should have a default volume and be able to be muted or set to vibrate easily--not randomly.
2 things - if you enable the custom lock screen, it should alleviate switching of the volume.
Also, there is an app in the market that prompts you in case the rocker switch has been pressed before actually allowing you to verify you really were trying to change the volume. I will look for it in a minute for ya.
