Help Voodoo and backups
N30wolf
Is there any way that I can create backups for the vibrant that work without installing and reinstalling the voodoo lag fix everytime? I know that clockwork recovery doesn't work with voodoo installed, and messes up my phone if I try it. :(
Nope. That's the cost of running Voodoo. You can manually copy files from the SD cards, but if you want a nandroid, you're stuck.
