sremick
Android Expert
I heard that the lag-fixes might do permanent damages to your phone... Any truth to that, or is that why this Voodoo Lag Fix is significant over the OCLF2.0?
They work in different ways. OCLF, for example, adds a virtualization layer to your data partition and then runs a ext2 (17yo technology) on top of that. Which is a fragile, dangerous setup. Voodoo on the other hand uses a native ext4 filesystem but to do this it replaces your main kernel with a hacked one that is based on older code than what shipped with the Captivate, so it has quirks too... and when you "uninstall" Voodoo, it doesn't remove this hacked kernel. Perhaps this is the "permanent damage" you are thinking of.
