VZW Backup sending Data to Droid
superdesi
Does anyone know if the VZW Backup application can send contacts to the Droid? I'm currently using a non smartphone that uses VZW Backup to back up my contacts on the phone online somewhere. I dont know if the Droid is compatible with the VZW Backup app tho.
login to to your verizon account online, go to the backed up number list, and export it as a csv file. then import the file into gmail and sync your contacts.
Thank you very much sir. Now all I have to figure out is where to get a droid from so I can import that csv file in it. :D
