VZW GT paired with BT headset, any issues?
katinsc
Anyone tried to pair their VZW GT with a BT headset? Any issues?
I know there are issues with pairing keyboard/mouse. I probably won't ever need those, although now there is a keyboard dock available. But I will want to use a BT headset.
If you had no problems, what headset do you have?
I haven't tried it but can you print with a tab? If I had a BT printer would that not work, too?
Disregard, I returned my VZW yesterday and purchased a TM Tab. I knew I was never going to be happy knowing the limitations of downgrades of VZW. So far so good. My DIvx movies will not play on the preinstalled video app. I did download Vplayer, which works fine. which I can see my playlist and if I have to stop it remembers where I left off..
I also like the guestures in Vplayer.. you can swipe your finger up and down to raise or lower the volume and you can swipe to raise and lower brightness. This player is awesome and it keeps getting better with each update. It's the only one I could find that played my .asf and .m4v files consistently.
thanks for the suggestion. Does this have a playlist? I find the only way I can see my list is going to My files- Download. The preinstalled app shows a playlist, so I can select.
Is that that because I don't have a sd card installed?
The most recent update lets you change the folder thats viewed when you launch Vplayer. The Apps Dev is working hard getting updates out. It's gone from Alpha player to Beta player and even Beta has had one or two updates already and thats only been a week or two. There should be release notes for it that describe the new added functionality. I like the fact you can pinch out to fill the screen.
