Root [VZW] ROM Index for the Verizon HTC One
Lykarsis
This qustion may need its own thread, but I am going to ask anyway.
I really want the google play edition of the HTC one. Is there a way that I can just buy one for $200 from verizon and then just root it to have stock 4.3 or 4.4, whatever it will take. Just trying to get around the $600 price tag
Are you wanting to use the phone on vzw? If so,youll have to stick with a vzw variant and root and run custom roms. If you're wanting to use on another carrier,you can purchase an unlocked device and fully convert it if you wish.
The sprint and vzw variants are unique and won't work on other networks,despite some gsm compatability.
i didnt mean to imply you couldnt run a GPE type rom,sorry if it came across that way.
i simply meant you cannot convert a cdma device to a fully functional GPE phone that will recieve OTAs :)
