kjarrett
Was a little concerned when I saw these DO NOT COVER the entire screen, then I thought to myself, why would it have to? It covers the main part you're always touching (other than the home buttons).
These are NOT crystal clear, they are slightly anti-glare. As a result, they do SLIGHTLY impact the clarity of the screen, not a big deal, doubt anyone will be able to tell from any pics I'll shoot.
Installation was easy thanks to dotted lines on the perimeter of the protector outer peel-off layer, a nice touch. (You remove this outer protector as the final step of the install).
Surface sliding is VERY SMOOTH.
Overall, I recommend these.
-kj-
-kj-
