Root [W.I.P]Very simple contacts/phone
biggiephil
Hey guys, I've only made a simple change in the colors of the numbers on both dial pads, while you're on-call and out of call :) Sorry if it's not very impressive it's my first :P Lgcontacts: https://www.dropbox.com/s/wq4u6pgnhwqmu5p/LGContacts3.apk New LGPhone: https://www.dropbox.com/s/a0cn66wcy7pqc60/LGPhone.apk
I assume most of all of you know how to install these, if not you copy the apks you've downloaded and move them to system/app and paste :) (reboot is needed)
Permissions for both are rw-r-r--
Updates: Simple color changes on the "Dial" and "Contacts" and "BlueTooth" and "Mute" also "Merger call" and "Speaker" on-call
Hey guys, I've only made a simple change in the colors of the numbers on both dial pads, while you're on-call and out of call :) Sorry if it's not very impressive it's my first :P Lgcontacts: https://www.dropbox.com/s/wq4u6pgnhwqmu5p/LGContacts3.apk Lgphone https://www.dropbox.com/s/a0cn66wcy7pqc60/LGPhone.apk
I assume most of all of you know how to install these, if not you copy the apks you've downloaded and move them to system/app and paste :) (reboot may be needed not sure)
Make sure you tell them the correct permissions and yes you do have to reboot to see dialer..
Ehh you sure this is right? I replaced it and fix permissions and restarted phone. Now the dialer and contacts are gone. And my data is gone. I pulled the originals from mini F. And fixed it. But it didnt work
Half and half. It should be correct. Works on mine o.O
