DFRESH
Yep, the picture above represents all of those that cry so much about their phone...
Ask yourself why you cry so much about your HTC Hero?
Have you asked yourself that maybe YOU are the problem and not the HTC Hero?
Making threads about how much you hate the HTC Hero and crying about it won't solve anything!
How about you make a positive thread and find out if some of us can fix your problem?
Rooting has plenty of benefits, it can fix many issues! Believe it or not...
Oh I forgot, YOU didn't root before the 2.1 update. YOU are stuck with a 2.1 stock ROM ....*POINTS AND LAUGHS AT YOU*
My HTC Hero is running perfectly fine, my only issue is BT. But guess what? I stopped using BT ....
And another thing....If I'm not happy with the ROM I'm running right now, I can always switch to another ROM that will fit my needs. Too bad you can't do that because YOU ARE NOT ROOTED!
So all you cry babies out there...seriously...STOP IT! JUST STOP!
