Help Wake phone screen by volume instead of power button?
warock56
I have tried these apps to try and unlock the phone by the volume buttons.
https://play.google.com/store/apps/details?id=org.firezenk.wakeall&hl=en
https://play.google.com/store/apps/...wsMSwxLDEwOSwiY3ouZGVzdGlsLmZpeGJyb2tlbnBiIl0.
https://play.google.com/store/apps/...EsIm9yZy5saWJlcnR5LmFuZHJvaWQuYW55dW5sb2NrIl0.
and another one I cant remember right now with no luck, this perforated cover makes it a little tricky to press the power button, before I put a little piece of plastic or something in between the cover and the phone to make it a little easier to press I wanted to know if there was a way to unlock it by pressing the volume buttons which is more comfortable.
Does anyone know of a way/program that will do this? Thanks.
so looks like theres no way to do this, no easy way at least. I have tried some other apps today with no luck also.
my power button has not been responding right away like it used to. i have to press it 2 or 3 times now to get the screen to turn on. i'm trying out Auto Screen On from the store and i'm turning on the screen on by touching the proximity sensor twice and it seems to be working like it says. i hope the it just doesnt turn on all the time in my pocket. Has anyone tried this app?
I saw the above post and installed Auto Screen On a few days ago. So far it's working well and I'm happy with it. I keep the phone in a holster so with it set for double-tap of the proximity sensor it won't be able to turn itself on by accident.
