Help Wake phone
Same issue here. I would love to be able to click the center button and have it bring up the lock screen. I think that HTC didn't do that though because it would "be to similar to the iPhone." Still would like that feature though.
Although there are 3rd party apps that can make your optical trackpad and/or volume rockers wake the phone, none of them are 100% reliable and some can be quite buggy, so keep that in mind.
I really want an app that lets me double tap the black screen to then bring up the swipe lock. Or even just press the optical pad. This would make the phone much easier to use IMO. I looked up the apps listed in this thread on the Market, but they didn't appear to help with our problem.
-cyrus
-cyrus
Download "No Lock" from the app market. Put it one one of your 7 screens and set it to "Unlocked". Pressing the volume button will unlock the phone/screen as will pressing and holding the optical pad.
Check out "screenmodewidget" in the market.
It allows you to just hit the volume button to bring up the phone
A week after I purchased my new HTC Incredible, the power button would fail to turn my phone off most of the time.
Upon removing the rear battery cover, the button worked just fine. I realized the problem was not the power button, but the opening for it. As the front and rear covers were designed to come together (i.e., form the front and rear button opening), they squeezed together too tightly on the button. This interfered with button movement.
I took the rear phone cover and gently filed away much less than 1mm (around the opening) using a diamond-tipped microdermabrasion device. The amount of plastic removed was so minimal, no can tell by visual inspection. This fix worked like a charm; I have been using my phone for days now without any problem recurrence.
