King Stampede
Member
Anyone else having a problem of not having the screen turn on when you press the power button from sleep? It doesn't happen often but it does happen. This is my second Captivate as my last one would shut itself off randomly and that phone also had this problem.
Yes, I make sure I pressed the power button and waited a couple seconds to make sure it just wasn't lag but I can guarantee you it is not. Like I said, it doesn't happen all the time but maybe once every 2 days. I'm guessing it's a slight problem with other users as it happened on my last phone but I'm not sure. Hopefully it's a software issue.
