I've had my s4 for about a month and have been very happy.
Last night my battery was at roughly 70% charger when I plugged it in for the factory charger for the night and went to sleep. This morning, when I woke up, the battery was dead and the phone wouldn't boot. There was no evidence of any overheating alarm or issues during the night.
I figured that the charger had come unplugged and the battery had died, but it seemed like there should have been enough battery life to make it through the night.
When I put my extra battery in the phone, it booted up normally and everything looked fine. However, when I plugged it into the factory samsung wall charger, nothing happened. I tried an old wall charger from the droid x2, and it didn't work either. However, the when the usb cable was plugged into a usb port on my computer, it does charge, but my PC says that the "device is not recognized" where previously it would recognize my s4. My verizon car charger seems to work as well.
I've since tested both batteries (I have a separate battery charger) and both seem to work fine and have no issues. The life of both seems to be normal and the phone is operating normally except for (1) the wall chargers not working and (2) the phone not being recognized by the computer. I've also cleaned/fussed with the charging port quite a bit to see if it is just a dirty terminal issue.
I'm guessing my next step will be a memory wipe/phone reset. If that doesn't work, I'll probably look into swapping out the charging port.
Any thoughts on what might be going on with my s4? Has anybody had a similar issue before?
