If the SBC kernel slowly charges the battery to 100% does that mean a wall charger should not be used?
If I understand, the SBC kernel such as Agressive Freedom slowly charges the battery to 100 percent. If I use a wall charger (where I take the battery out), the battery is disconnected from the phone so the kernel has nothing to do with charging the phone. If I have an SBC kernel, should I only charge the battery while in the phone to let the kernel do it's thing or does the wall charger also slowly charge to 100 percent?
