Help Wallpaper Creation
Hello Everyone,
I am in the works of creating a wallpaper for the prevail, I am wondering what a good size would be for the overall image? Should I make it exactly 320 X 480 which is what the screen resolution is?
Also, is it possible to create an animated wallpaper? For instance, if I create a animated wallpaper in photoshop, will that be accepted and do the animations, or not?
Animated wallpapers will not work. Not sure how the live wallpapers work but that's outside my pay grade. Google is your friend in making live wallpapers.
As far as making the image exact size to the screen that's only going to work if it doesn't scroll. If you'll notice that when you move from screen to screen the wallpaper moves with you to a certain extent. Its not to the exact dimensions of the screen.
Good luck.
