Help Wallpaper error
Katalex
Hello
I have a Samsung 10.1 tablet and the problem with it is that each time i turn on the device from the start button there is a message jumping on the screen saying:
Sorry!
The application Tablet Wallpapers (process com.tabletapps.wallpapers) has stopped unexpectedly. Please try again.
Force close / Report
So in order not to close my device because i want it ON i press the Report button and then another message is jumping saying:
Report error in Tablet Wallpapers
Description (optional)
Include system data
Share system data with Google, to better diagnose the problem.
Privacy policy
Cancel / Preview / Send
How can i get rid of these?
Factory reset clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.You may want to perform a hard reset if there are problems with the device that you can’t seem to solve using any other method.
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
