Help Wallpaper help
LFC958
My previous phone was an S3 & i was able to have 1 wallpaper on the lock screen, & a different one on my home screen.
Having spent ages trying to find how to do this on the G, it appears not to be part of Android but a feature Samsung added.
Anyone any ideas on how i can do this on the G ?
I am not a wussy apple user to scared to do a bit of work ( despite using a Macbook air).:rolleyes:
I think you need to look under the security settings and lock screen settings are in there.
I'm sure the Mrs has a different lock screen pic.
Thanks
Just had a look Screen security heading only has choice of method to lock i.e. slide, PIN, PWD etc - trusted devices - enable widgets. :(
It might be something that you'll have to use a 3rd party launcher for; ie Holo launcher, Nova, etc.
Launcher isnt gonna matter you have to use a 3rd party lockscreen. Go locker holo locker ect ect. They work ok. Some of them make you buy the full paid version to change the wallpaper on the lockscreen though. Being able to have different wallpapers for the lockscreen and home screens on the s3 is a feature of samsungs touchwiz and not of android.
Thanks for the reminder.
