Help Wallpaper is huge, help plz
Any pic i try to use as a wallpaper is huge. I know its suppose to cover all the sliding screens but no matter how big i recrop it, it still doesnt work. Especially compared to some of the screenshots i've seen of other ppls phones... I"m obviously new to android phones so i would appreciate some help.
thanks
I believe the right resolution for the Thrill is 480x800. Therefore wallpapers need to be in that ratio in order to be perfect.
if its a pic i take will i need to set that up in the camera before i take it? or is there a way to set the resolution with any pic?
thanks
I toyed with resizing pics for the longest time...then I found the app "wallpaper wizardri"
it's in the market, and gives you a slew of instance resizing/crop, and scrolling options.
check it out!
