Thefoodman52
Android Expert
Mmmm kay. Here's my issue: The orange highlight box when cropping for your background (BG). Normally, (when held in portrait) the orange box is longer horizontally than it is vertically, which is normal seeing as the extra length is being used when you swipe across your home pages. My issue is this: after downloading and using Pandahome, I must revert it back to defaults through manually resetting it to get the orange box back. Currently, when I select a wallpaper, it only allows me to set a static one, I.E. when I swipe the image is basically glued down and doesn't change when I swipe. How do I fix this? If this is Pandahome acting up, I can deal with resetting. If it's something worse... uninstall is going to happen.
