Natively, you can only have one 940x800 (I believe that is the correct dimensions) image across the entire board. However, I do believe there are apps that will let you have frames, one on each screen.
That I do not, although it was from these very forums that I saw the answer to your question. I don't remember the name of the thread though, but try searching around and see if you find anything relevant.
