leeanne172
How do you use the APK file once downloaded to PC?
If you have dropbox then put it there then just install it on the phone from the DB app, that's what I normally do
You cannot change resolution of the screen. If you use the resolution I posted earlier, you will get what you need.
Thank you so much for this, sadly Wallpapapryus was a playstore only app and I am never going to use this store. Other than that thanks again.
