Hello. Does anyone here use the Wanamlite ROM?
If so, I have a few questions.
1) On his site it says to get MTP back you need to flash a patch which you can download. How do you flash this patch? Is it just a case of putting the zip file on my phone then installing it from the SD card using CWM?
2) He also says that he has disabled the voice talk option when you double tap the home button for faster home load. He says to re-enable it you can push a stock
