NiceGuyJon
Hello all, I was wondering if you can help me. I bought a kyocera hydro for $22 on Amazon with the thought that it would be a dedicated MP3 player, intending to load it up with music and not use up data by streaming.
It has been working okay, but for some reason I can't tell Google Play Music to save pinned music to the SD card, so this greatly limits the amount of music I can save to it even with my nice big SD card I bought for it. I was wondering if you guys knew a way I could turn it into just strictly an MP3 player? Ideally, I would like to remove all the apps and phone bits from it, and just have it strictly play music. Is it okay to remove literally everything including phone, data, etc? If I could do that, then I would be happy to just put all my music directly on the SD card and not have to worry about Google Play Music.
Thanks in advance!
Thanks in advance!
