Root Wanting to add more.
Psywar
I am going to break this post up using -- cuz it ended up being a long post.
I ended up jumping on the Bandwagon yesterday morning when I got home from work. I downgraded then upgraded back to 2.2 w/ root!
Here is a picture of my phone at the HBOOT area:
(Sorry about the other forum spam in the background of the photo.)
As you can see I did the UnrEVOked Forever install.
I am currently running Fresh 3.1.0.2 and I have the newest Amon RA Recovery 1.8.0.
I like the basic look of the Stock HTC Evo Rom, but after seeing some of the cool themes out. Their are bits and pieces of the themes that I want.
Well honestly not much. I really want the Circle Green Battery but its not a full circle its broken up in to sections lol.
Is it possible to just get these bits and pieces and flash them to use them?
If so any idea where I can find bits and pieces of themes to flash?
Radio's
I do have sort of another question about the Radio's. I read you just download them and then use Amon RA Recovery and then just flash them.
Is this how it is done?
If so can I just place all of the Radio Flash files on my Root Drive and just keep them there?
Also are their any programs I can use on my HTC Evo to figure out which Radio may be giving me a better signal n such?
Why I am Concerned about Radio's
I do not see many posts about the Radio's so I assume most people just grab the current one and then they call it a day.
Here is my Problem: I live on the Border of Michigan and Canada.
In my Evo Settings have have the Do Not Roam and No Data Roaming Checked on my phone.
Because of this I quite often have no signal/bars on my phone.
Why don't I just use Roaming? Well lets just put it this way after only a few days of use the Canada Data Roaming Charge is well over 30bucks extra.
I contacted Sprint about this issue the only thing they ever tell me is pretty much "Sorry".
So that's kind of why I keep posting about the Radio's. I am not worried about battery life if I can get a stronger signal.
The main reason there is because my phone is always looking for a signal and going in and out of Service so much that it just drains the battery quick anyways.
Image file question
To do the Rooting process on the phone I had to get a file called: PC36IMG.zip
This file is still sitting on the root of my phones SDCard.
Should I take it off? When Exactly is the PC36IMG file used? Just when installing Roms? I guess I don't understand exactly what it does.
I think thats all my questions/concerns for now. :)
I will try and keep all my questions in this thread!
Thank you all in advance for any/all help!
