Guru82
Hi,
I've been playing with my Huawei G510. Believe I've learnt some valuable lessons and wish to share, will also asking the community if you agree...
I use Clean Master, but now never ever clear/force stop apps, because the system is capable of managing itself.
Never use AutoKill apps.
Never remove System Apps that are embedded, unless you want to drain more battery. Having an app load and sit dormant is better than the system attempting to start (continually) something that doesn't exist. It not only chews your battery, but also makes your phone lag considerably when Android System is trying to load those apps. Perhaps one or two things you simply hate can be disabled/uninstalled with a root app remover, but go crazy and you'll be going backwards.
Am I right?
Am I right?
