Root Warp 4G Stock B13 KitKat 4.4.2 Deodexed and Unmodified
SuperR
Android Expert
Recognized Developer
DISCLAIMER: By using this rom, you agree that you are the only one responsible for anything good or bad that may occur. Use at your own risk.;)
For Boost Mobile ZTE Warp 4G N9510 only.
Completely Unmodified Stock B13 KitKat 4.4.2.
warplte_Stock_B13.zip
Debloated and Deodexed Stock B13 KitKat 4.4.2 with Root.
warplte_Stock_B13_Deodexed.zip
/system/app/Books.apk
/system/app/ChromeWithBrowser.apk
/system/app/ConnectionsOptimizer.apk
/system/app/Gmail2.apk
/system/app/Hangouts.apk
/system/app/Magazines.apk
/system/app/MobileZone.apk
/system/app/Music2.apk
/system/app/PlusOne.apk
/system/app/SpanishPack.apk
/system/app/Swype.apk
/system/app/talkback.apk
/system/app/Timer.apk
/system/app/Videos.apk
/system/app/WorldTime.apk
/system/app/xtra_t_app.apk
/system/app/YouTube.apk
/system/etc/recovery-resource.dat
/system/lib/libgames_rtmp_jni.so
/system/lib/libSwypeCore.so
/system/lib/libvideochat_jni.so
/system/priv-app/EmailZTE.apk
/system/priv-app/ExchangeZTE.apk
/system/priv-app/SprintID.apk
/system/priv-app/SprintInstaller.apk
/system/priv-app/ZteBrowser.apk
DOWNLOAD:
warplte_Stock_B13_NOT_FLASHABLE_removed.zip
NOTE1:
If you have not updated to 4.4.2 (B13) via OTA, you should flash this partition updater AND the rom of choice. You only need to flash this once.
NOTE2: Your device must have CWM/PhilZ/TWRP to flash ROMs.
NOTE3: These zips are unsigned so you will need to disable signature verification in CWM/PhilZ before flashing.
Flash in CWM/PhilZ as follows:
  1. Download ROM of choice
  2. Put the ROM.zip on your sdcard if not already
  3. Reboot to CWM/PhilZ Recovery
  4. MAKE A BACKUP!!!!!!!!!!
  5. Wipe data/Factoy reset
  6. Install partition updater from sdcard (see NOTE1 above)
  7. Install ROM from sdcard
  8. Reboot
  9. Enjoy!
Other Downloads/Links:
SuperSU - Flash this after the unmodified ROM to get root
warplte_stock_B13_kernel.zip
warplte_stock_B13_recovery.zip
warplte_Stock_B13_ext_sdcard_fix.zip
Root instructions for full stock 4.4.2 devices
Thanks to:
Chainfire - For SuperSU
ZTE - For bringing KitKat to the Warp 4G
There is definitely a stagefright fix involved cuz I have to hit Download for every pic that comes in SMS. Will ya plz post a partition downgrader/reversal so ppl (like me) can revert back if desired?
OK.. I am officially hating this B13! Dang thing won't let me move pics from internal to ext SD, won't let the apk theming hacks I've been using last cpl yrs work properly... GRR!! I've even given the ROM a WK or two before my decision. Screw the Stagefright BS, I really wanna go back to B12 cuz I'm so frustrated with this backwards lockdown. @SuperR .. May I plz get the partition downgrader for B12?
I think the external sdcard needs a fix like the TB fix I made for B12. I will add it to the OP soon for you.
Regarding the B12 downgrader, it should not be a problem. I will make it for you.
It is unlikely the apks can't be themed the same way. The sdcard fix might help with that too if you are working with apks on your external sdcard. Either way I will make the sdcard fix and partition downgrader so you have options :)
