Warp Sequent mod screenshots
animusfl
Member
I am not responsible if you brick your
phone or make it unuseable! Make sure
you have backups and know how to fix
it if you screw it up!
That being said the sequent is definitely moddable. I did not write
or create any of the modifications seen here, I just figured out how
to apply them to my phone using apktool on linux and wanted to
share some screenshots. I've changed the system font and also
changed the battery icon to a 1% circle battery with animated
charge. If you've tweaked your sequent and want to brag, feel free
to do so here!
Happy Modding:aetsch:!
EDIT:
Well, I've made some progress and learned some things about editing xml files and about SystemUI.apk in general. Thanks go to Ticklefish on XDA forums http://forum.xda-developers.com/showthread.php?p=28643215 for the great tutorial! I was able to center my statusbar clock properly using method 3 which is a RelativeLayout rather than a LinearLayout. I don't use windows so I wasn't able to try out Tickle My Android, but it looks like a pretty cool tool.
edit: added some screenshots with a transparent status bar, center clock and 1% circle
battery. Launcher Pro did not like transparent statusbar, but np with Apex Launcher.
Is anyone else doing this? Have some mods to share? Want a tut and perhaps my
SystemUI.apk? Feedback?
