I played videos off ESPN off both 3g and wifi w mxplayer and not the stock player.
I can play them with MX player too, it is the stock player only that has this issue.
On several occasions I did pull the SD card out prior to dismounting like you are supposed to do. I may have screwed it up that way. Who knows...to be honest at least I can watch movies again. Its such a relief to solve that.Knox...been thinking about why when you purchased a new card your "videos" began to work. This might be a no duh but I wonder if the phone in order to run video more efficiently is commandeering a large amount of memory as a buffer and as you loaded more data on the card it got to the point that it did not have enough memory to "buffer" the videos any more (or at least the big videos). But when you purchased the new card it all of a sudden had memory to burn. Just a thought and if it is true then you might see the problem pop up again when that card gets closer to full. Of course it could just as easily been a bad card.
Im having same problem. Got this phone today and can not stream. Help!
