double b26
Member
So, last night, before i went to bed, i went to power my phone off. It had been on charge for most of the day, and when i pucked it up, it had the led lit green, but the phone wouldnt respond to any buttons. So naturally, i pull the battery, give it a few seconds, and try rebooting. Nothing! It wont light the led when plugged in, or anything! Completely dead.
I bought a replacement battery for it a couple months ago, so my first thouht was a bad battery. I dug out the original battery for it, which still works, but depleted quickly. Still nothing! I tested voltage on both batteries, and both show about 4 volts. So they appear to be okay.
So from the looks of it, the phone is just dead. Idk what happened to it that would make it break from setting on a table, hook to the charger, but that appears to be what happened!
Before i trash this thing, does anyone have anything i could try to bring this thin back to life, or is it just time to upgrade?
(Ive had the warp since launch, and really like it with root and custom rom. Hate to move on just yet!)
