Water damage! What should I do?
didons
Hello!
Unfortunately I left my Galaxy S2 under the rain for a few hours.
I left it drying for three days using rice and then I tried to turn it on.
It works! But it says something like charging paused, voltage too high and then it looks like it's charging even if it's not.
I bought on ebay a usb charging port with mic and I hope that it will fix the problem... Or not?
But there's another problem:
I cannot open my gallery! It keeps saying "media scanner running"
Any suggestion?
The phone seems to work fine except for these problems!
did you receive your new usb port yet? i also purchased one off of ebay to fix mine...it wont even turn on anymore.
