water damage
katie23
Hi everyone...could i please get sum help? Last night i dropped my htc desire hd in a sink full of water..only for a few seconds i removed all cards and battery straight away placed it in the water tank cupboard to dry out overnite but when i turned it on today the phone seems to be working fine but i have noticed a large white mark running right down the center of the screen i was just wondering will it dry out and go away or will the screen need replaced? Thanks
Hello and welcome to the forums - thanks for joining!
Sorry to hear about your accident... never good when this sort of thing happens!!
Your best bet would be to try and put the phone in a bag of (uncooked) rice in an airing cupboard over 24-48hrs to ensure that it is fully dry. If the white mark is dampness, then you would be best not using the phone, to avoid further damage!
I hope that you manage to get rid of the white mark... feel free to come back and get more info... you might like to head to HTC Desire HD - Android Forums - the sub-forum for the DHD - I hope to see you in there :)
Hi and welcome to AF!
Keep the phone powered off, with the battery and SD card removed, for a while longer as moisture can linger inside the casing for some time. The ideal solution is to place it in a bag with a small amount of uncooked rice, as this will absorb excess moisture.
You may find more specific advice in the HTC Desire HD sub-forum, btw.
Good luck!
