Water damaged note 3
tomajd
First of all, hi everyone, im new to this whole forum thing and i need some help.
A couple of days ago i managed to forget i was wearing a bag with my note 3 in it when i walked into the sea :banghead:
Anyway it was in the wet bag for maybe 20 seconds when i relised and took it out and took the battery straight out. I took it all apart and dried it out for a few days and when i went to turn it on mos of it worked.
It turns on and everything but the s pen has stopped working completely (no undocking sounds either). also when i open the camera app i get all the buttons which dont work and just black in the background.
My question is are there parts that i can (fairly easily) replace to fix these two problems and how much will it cost.
Thanks in advance.
If you haven't yet, you should bury it in rice for a day or two. That will suck out any moisture that merely letting it sit out and dry will not.
