Help Way to make call log default?
odanko
On my blackberry storm i use to be able to make it so that when i press the phone button my call log would show first then i could switch to the dialer if i want. Just trying to save the extra key stroke, is there a way to make it so when i press phone the call log will show first not the dialer? Thank you!
Not that I can tell; it definitely defaults to the dialer. Having acknowledged that I must say its a pretty small amount of effort to hit call log from there. I understand the principle behind your desire. In reality, you might just have to deal with the one extra click
Yeah I can't figure out a way either. LauncherPro certainly doesn't allow this... The only thing I can suggest is finding an APP that directly opens to the call log. Then, you can change this shortcut with LauncherPro. Best of luck and sorry if I'm not of any help.
