My Weather app no longer animates when i open it. Not the widget or lock screen, the actual app it self. It used to then all of a sudden stopped. It still plays the ambient sounds but no picture; all black screen with weather info. Anyone else had this issue?
Yes. Weather is set to sync every hour/when i open app, which it does update it just give that cool current weather animation like it used to. I'm positive a hard reset will fix it but i've got upwards 200 apps and until i can get Titanium Backup working i refuse to reset. Just wondering if anyone else had encountered this.
Ha. i knew someone would say that. 566mb free. And if i wanted i could push the majority of those to the sd card. But i ended up fixing it. All i did was go to the demo menu and watched those and "magically" the main animation started working. But thanks for your support
perhaps probably a temp fix? since you "gave focus" to that app it gave it priority over some other apps. id still monitor it and see if it acts up again...
