shyFluttershy
Hello.
Is there any way to change which weather widget shows up on the lock screen?
Right now, it pulls the info from the AccuWeather widget on the TouchWiz launcher. The thing is, I use a different launcher and a different weather app. The AccuWeather info on the lock screen does not update unless I explicitly go into TouchWiz and refresh the widget. (I had some really strange weather reports on my lock screen for the longest time before I realized this was the case!)
Thank you.
Thank you.
And with any luck, there are at least a handful of decent ones that are free.
