C calvinrw Member Jan 20, 2013 #1 Can the weather update rate be changed and how? It appears to update every hour from what I can tell. Thanks! -CRW
DragonSlayer95 Resident Air Bender Jan 20, 2013 #2 If you mean the built in weather app, you may be able to go to accounts and sync under settings and choose to update sooner then one hourm DS
Ag76 Member Jan 20, 2013 #3 I've also tried to figure out how to make the default weather app in the Circles widget update more often, but so far haven't been able to do so.
