Help Weather widget blank
vinnyt225
Member
im on stock froyo 2.2 and sometimes the weather widget just goes blank. it fixes itself if i remove the widget then re-add it. is this a known bug?
I have the same problem.
Also, can you log into Twitter from your phone? I can only do this in the browser, but client apps like Seesmic, Twidroid or even official Twitter app and Peep won't log in.
Quite a few of my widgets are gone when I go to their page. Instead is a message saying "Problem loading widget", or something along those lines. I have to re-install the app for the widget to be listed with the rest of my widgets again.....very strange. It only seems to occur with apps that I have downloaded from various websites. Never happens with apps I get from Market, so it may be bad apps to begin with for me...
