Help Weather Widget
Note that Beautiful Widgets has changed the look of the clock and no longer looks like the HTC sense widget on the incredible. This is something that I miss about the incredible and beautiful widgets is similar but not the same.
There are some HTC-esque skins available for Beautiful Widgets. From the weather screen, go to Menu > Skins to view and download them.
'Fancy Widgets' looked a lot like what you describe. It's been removed from the marketplace (HTC cease and desist?).
Hmm, I wonder if you search Google for Fancy Widgets APK would something interesting come up? Not that I would condone downloading it from a message board (for example) and manually installing or anything...
its easier than you might think..... :)
i haz the .apk
Yea I finally found a skin, however i had to manually add it. When I pull up the Skins for download in BW I only get 12 or so and they look nothing like the HTC sense.
Now I have this. It is really close the only difference so far is that the annimation is to the right of the temp instead of in the middle. But other than that I am happy!
My beautiful widget is not in sync with the actual time... i have to lock and unlock the phone to get it to update.... does anyone have this problem or is it just me?
I tried both beautiful widgets and did not like it at all compared to "weather & toggle" widget on the market with the H7t skin, its got the correct look and gives you the FULL animations with the rain drops and windshield wipers when it rains and clouds, etc.. its the best!
