Weather widgets skin
brettlewis
Android Expert
does any know how to properly skin weather widgets? I keep getting invalid file type and all im doing is writing over the default files...
Have you tried downloading skins from within the app? They have a big selection, if your trying to add in your own then I'm not sure why it is giving you trouble BUT if you contact the dev he should be able to help you and he has always responded very quickly.
I figured it out... I was missing one file from it and I think it only will open if all the png images are included
