Help Weatherbug will not update while using Juice Defender...ne ideas?
Helenoftroy08
Im using Juice Defender, and no matter how I set up my profile to enable connectivity for weatherbug, I ALWAYS get the message that weatherbug failed to load its data. Ne one else experience this, or have ne suggestions?:confused:
I found weatherbug to be a little too obtrusive so I deleted it (Weather bug plus when Amazon was giving it away). I found it just as annoying on my home computer. I'm guessing Juice Defender has the same attitude towards weatherbug that I do. Does weather bug work fine when you stop Juice Defender? If it does then at least you know it's Juice Defender that's inhibiting connectivity. If it doesn't then you can guess it might be the Weatherbug servers.
I'm running Juice Defender (Ultimate version), didn't put in any special exceptions for Weatherbug and it's working fine, so I'm not sure why it's doing that for you.
I think u rite about the weatherbug servers bcuz weatherbug does work when I disable JD
