web pages wont load
jedijim69
My tablet (mach speed trio stealth) will connect to my wifi but will not load web pages. I just upgraded from a Belkin N300 to a N600 thinking that was the issue, It has loaded and worked fine a few times but majority of the time it will not. my laptops work fine but the 2 tablets have issues loading pages but not connecting to the wifi
Welcome to the forums!!! What type of encryption does the router have? I know i had problems with older devices of mine (pc, tablet) connecting to newer encryption types like WPA2-PSK [AES].
Are they being assigned IP's properly through DHCP? If you have a guest account set up on your router, disable it. Sometimes devices will jump between secure and unsecured guest accounts if it thinks the signal on the guest account is stronger.
