Webtop Entertainment Center
D
Deleted User
Guest
To enable the Webtop Entertainment Center, make sure that you are using Motoblur as you homescreen launcher. If you are using Launcher Pro and attempt to enable the Entertainment Center nothing will happen.
works fine with Go Launcher Ex. you can freeze "home" just dont freeze "Entertainment Center" or any other docking services (car dock can be frozen if you dont use the car dock)
Sorry, but I am using LauncherPRO and my entertainment center works just fine. When HDMI is plugged in, it gives you an option for the entertainment center. I also have the webtopmod so i get options for webtop or entertainment center, in webtop you can also switch over using the link on the bottom. Dunno what you are trying to state here.
