Help weird charging problem
Dingding
Droid Charge has a weird charging problem,some times it will charge the battery, some times it will kill the battery on charge,or no charge at all.It will charge at a resonable speed sometimes, sometimes very slow.Battery life is ok sometimes but very bad on othertimes even with very little use.I have done all the easy stuff different chargers home,car,usb, makes no difference.New batteries did not help. No tech support help,no web help.I have read many people have this problem with other phones.
thank you for your time, Dingding
There are free charging current apps you can install (I use one for Samsung, so a link to it wouldn't do you any good) so you can see how much charge you're getting. You could have a bad cable, a bad microUSB connector (or it could be badly connected internally) or a bad battery, just to name a few possibilities. You have to determine what the problem is befoe anyone can tell you how to fix it.
in my message i have tried all that easy stuff, Droid Charge has a weird charging problem,some times it will charge the battery, some times it will kill the battery on charge,or no charge at all.It will charge at a resonable speed sometimes, sometimes very slow.Battery life is ok sometimes but very bad on othertimes even with very little use.I have done all the easy stuff different chargers home,car,usb, makes no difference.New batteries did not help. No tech support help,no web help.I have read many people have this problem with other phones.
but thanks for your time Rukbat
:Dingding
Droid Charge has a weird charging problem,some times it will charge the battery, some times it will kill the battery on charge,or no charge at all.It will charge at a resonable speed sometimes, sometimes very slow.Battery life is ok sometimes but very bad on othertimes even with very little use.I have done all the easy stuff different chargers home,car,usb, makes no difference.New batteries did not help. No tech support help,no web help.I have read many people have this problem with other phones. Also when the phone is trying to charge it will make a ding ding sound once in awhile ,how i made my user name. No one knows whats wrong yet.
thank you for your time, Dingding[
