Weird Controller lag every few seconds
I'll be using an Xbox one s controller via Bluetooth to play mobile games and every few seconds it will lag in a weird way and I don't know if it's my controller or phone. How can I fix this?
try a different xbox controller. as well as try using the laggy controller on a different phone. this will determine which is the issue. i do not think there is anything else you can do. i mean there is no software tweaks when it comes with controllers.
It'll really suck if there is no way to fix it but I'm pretty sure it may be the phone because I tryed playing it with a friends controller and it did the same thing
The phone has 3GB of RAM.
Perhaps that is not enough to run a game like that, especially when using an external contrroller- that uses even more resources.
Heck, I am not a very good typist, and I experence lag when typing 'fast' {fast for me} with my bluetooth keyboard on a 1GB device.
No it's not that because the phone handles the game perfectly fine it does it with all mobile games even stadia and that doesn't need much processing
Given that in another thread from last year, someone else was reporting the same issue with an Xbox One controller and another Samsung device. Any "fix" would very likely either need to come from Microsoft or the Android device manufacturer.....Microsoft will probably say they only support Xbox One controller with Xbox One console....anything else...Good luck!!
Has anyone else tried a Bluetooth Xbox One controller with another Android device, that isn't Samsung?
I've never had a problem with non Samsung phones
