Help Weird Issue
smartmanvartan
Android Expert
I have a new rom out and so far i don't have any bugs execp for one... Mixology drink recipes.. it crashes when you open it... anybody else having this issue on other roms?
Hey smartman, always good to see new devs.
It's hard to say what could be causing the issue. Have you changed the density in the build.prop? If you change it in the build.prop...it can cause errors.
What else have you done to the ROM? A little more information would be helpful to us :)
I ran it through the kitchen added swap app2sd zipalinged bash ... the works... also unlocked the tether menu as far as the build prop i tweaked it with dns examples but thats about it... whats weird is that i have tested it with a very wide variety of apps of different types and its the only one that does so...
It could just be an app issue, then.
My suggestion is if you could flash another ROM like...n00b lets say, and give it a try. If it happens on multiple ROMs, it's an app issue.
