Help Weird Problem with Desire
sarf
Hi,
Operating Mode: WCDMA/GSM AUTO
Data Plan: Yes
Ordered the phone from Expansys, Kuwait.
Current SW Ver: Android 2.2
I have had this problem for a while now. When the phone is operating on WCDMA/GSM Auto, anyone trying to call me gets the phone as switched off. When I switch it to GSM only, it works absolutely fine.
I have tried all the possible reset methods it works fine for 5 mins and the problem is back. I have the phone working on GSM now but it gets connected to Edge. Is someone else facing the same problem? Really upset with this because it is a awesome phone.:confused:
Sarf
Probably to do with the fact that if someone calls you while you are using data on 2G services, the data seems to take priority and the call is cut off.
On GSM it is working fine but when it is on WCDMA/GSM Auto the caller gets the message saying that it is switched off
